How to Easily Create Tests and Questions in Lectora e-Learning Software
Looking for new ways to add questions and tests in your next e-Learning course? Lectora® e-Learning software makes it very easy for you to add a variety of question types and assessments to your course. In Lectora, you can choose to create pre-tests, randomized tests or final assessments in which you can easily tack all scores and data with a learning management system or simple database.In this Inspiration Wednesdays webinar, Tara Roe shares outside-the-box ways you can use traditional tests and questions in your course. You will learn about different types of assessments, how to apply them to a variety of scenarios and how they can enhance learner engagement.Watch this video and learn how to incorporate pre-tests, combine multiple assessment scores and how to use stand-alone questions throughout your courses:
One great feature in Lectora is the randomized test function. This gives you great flexibility when you create your tests and makes it easy to create a unique test experience for each learner.
Here are a few tips to consider when you create randomized tests in Lectora:
  • Use a consistent number of questions on each page. Lectora randomizes by page, not question, so consistency in numbers of questions per page is key.
  • Make sure the total question weights for each question on a page are equal.
  • If you want to have questions chosen at random from all sections in your test, select “Random Selection of Pages” in your test properties to make sure it pulls from all sections.
  • if you want to randomize your test by section level, change the setting in your test propertiesto “Randomize by Section Level.” This allows you to randomize questions from specific test sections.
Do you have more ideas for tests and questions in Lectora e-Learning courses? Tell us on Twitter or Facebook. For more great Lectora tips, tricks and resources, check out the Recorded Webinar section in Lectora University.
