Find out what your learners remember from your e-Learning course by adding a Quiz with Snap! by Lectora® rapid e-Learning software. You can easily create gradable quizzes and submit the results to a database or communicate them directly to a learning management system.Within PowerPoint, go to the Snap! Ribbon and select the Quiz Creator.
In the Add Question tab, begin creating your Quiz by choosing from a variety of question types: True or False, Multiple Choice, Multiple Response, Fill In, Matching, Drag and Drop or Hot Spot.
Each question you select is added to the Question List. You can rearrange questions by simply dragging and dropping or remove questions altogether by clicking the “X” button. When you select a question from the list, you can easily customize its properties on the right. This includes entering the question text itself, images or audio, possible answers and feedback.
Reuse your Quiz within other presentations by exporting the Quiz from the current Snap! presentation and importing it into a new presentation.
You can also modify Quiz Options, like the Lowest Passing Score, Random selection of questions and submission options.
When you’re finished click “Preview” to see your completed Quiz or simply preview an individual question. Then click “Save and Return” to save your Quiz and to close the Quiz Creator.Watch the full video, Create a Quiz, and find more rapid e-Learning video tutorials and tips in Lectora University!To try Snap! by Lectora free and see first-hand how easy it is to create a quiz, download the free rapid e-Learning software trial.
